yes indeed they are all the discs that are bad but with a few of them I am also satisfied or even with the part number or a team that uses the same ones to find them.Do you need all the friction discs and the flat plates that go between? or just one friction disc?
I'll call my grove man on monday and see if I can get you a part #. I don't know if they are available individually or if its all of them as a "kit".
Got some part #'s for you
Friction Discs are 9974100594 should take 7 of them at $140 each
The steel discs have two styles, some have teeth and some have lobes/ half moons. You'll have to know which you have.
Lobes 9974102704
Teeth style 9974100591
Either style takes 8 and they are $37 or $30 each
My parts man says National recommends replacing the overrunning clutch while you are there. A new one is $3,513- so you might want to see if yours is still good.
