stumpjumper, move your center pivot forward, under the mast, fit a roller or small wheel under the backend to take your weight. make a new bucket as big again and fit drums about
3" in dia.Maybe 3-1/2" for the hoist line. For working,I would make the hoist on the right and the drag on the left, and make a wooden(plywood sandwich)crank disc with the handle about 6 or 7" diam.maybe even a little bigger, then you can use the palm of your hands as brakes to control the run-out. To get your rope length, put 3 turns on the drum then take the hoist up to the head sheave and down to the bucket about half the length of the boom out, read 1 1/2 boom lengths, please keep us posted regards rayman then take the drag rope straight out to the bucket.The cutting edge of the bucket should really be back about where it apears to be folded down a little and the pull point needs to be a little below the line of the top edge and out in front a little. The arch should be a little higher too. I can't make out how the bail block is rigged.
now just "gitterdun an git contracting"
