Slingshot ammo
Good afternoon we have a DT466 engine that is very slow getting up to speed . Trouble codes on dash screen are 1:1 613A and 1:4 613P . Are these related to the poor engine performance . Thanks !
Dt360DT466 is the code for low power...
Thanks for the information , getting a list of codes is difficult .The A means active. The P means previous. That 613 has to do with your environmental controls. So, nothing to do with the engine.
Thanks !The A means active. The P means previous. That 613 has to do with your environmental controls. So, nothing to do with the engine.
Yes I did , the filter is new and the screen has been cleaned . Have a fuel supply pressure of 55 .Dt360
8.3
5.9
345
304
4-53
6v53
Turoflow
There's lots of those codes for medium duty low power.
Till I'm done listing I may run out of page.
Any how have you checked the basics as in air and fuel filters
I am assuming you are checking the pressure at the quick coupler on the fuel filter cap. 55 PSI is on the low side the manual calls for 65 -75 PSI. There is a stainless steel restricter/orifice in the bottom of the fuel filter housing, its bad for getting debris on the seat causing low fuel pressure. Take it out and blow it out with compressed air. You can usually clean them , the last one I replaced was $107. It takes a 7mm allen socket to remove it.
Have a good look at the bottom of the filter cavity, is there a lot of dirt and rust built up? if so it will need to be cleaned, its a bit of a pain to get the housing out because of all the stuff in the way. You will need the special O-ring where the housing bolts to the intake and four olives for the steel lines.
The 04 to 07 DT466 did not have a fuel return line fuel returns through the restrictor/orifice to the fuel inlet so any dirt and rust will keep going from the restrictor/orifice through the transfer pump and back into the filter head until the restrictor/orifice has a buildup on the seat again which does not take long.
Morning the screen I mentioned is actually the little strainer basket in a housing that is screwed onto the bottom of the fuel filter housing . I checked the fuel lift pressure at the shrader valve on the fuel manifold at the front of the engine . I dont have a quick connect tool to do it at the fuel filter housing .What screen? You said 55 psi delivery pressure. You mean lift pressure? The lift pump is the thingy on the end of the HPOP. Speaking of HPOP, that engine is intolerant of leaks in the HPOP system. Little seeps coming out of that manifold on the side of the head is enough to make it run poorly. That’s a steel gasket in there that’s prone to leaking. Speaking of leaking, make sure you got no diesel leaks. Fuel leaking out means air leaking in. Make sure your fluid levels aren’t changing in wierd ways. Coolant should never change on a cool engine. Every engine burns a little oil, so make sure your oil level isn’t going up, or staying the same. What’s tricky is if the engine is burning oil at the same rate the fuel system is adding fuel to it. Check your blowby. Check your boost. If all that looks good, it’s probably time to bust out the servicemax and do some diag on that engine.
As far as we can tell there are no fuel leaks .What screen? You said 55 psi delivery pressure. You mean lift pressure? The lift pump is the thingy on the end of the HPOP. Speaking of HPOP, that engine is intolerant of leaks in the HPOP system. Little seeps coming out of that manifold on the side of the head is enough to make it run poorly. That’s a steel gasket in there that’s prone to leaking. Speaking of leaking, make sure you got no diesel leaks. Fuel leaking out means air leaking in. Make sure your fluid levels aren’t changing in wierd ways. Coolant should never change on a cool engine. Every engine burns a little oil, so make sure your oil level isn’t going up, or staying the same. What’s tricky is if the engine is burning oil at the same rate the fuel system is adding fuel to it. Check your blowby. Check your boost. If all that looks good, it’s probably time to bust out the servicemax and do some diag on that engine.
