sawdustmaker
I have a hydraulic gnome eating my lunch!
Let me start by saying I have 4500 psi from both pumps, and black smoke when it stalls the engine.
The machine is a '96 3400Q link-belt with some particular hydraulic issues that i cannot find to save my life.
I have been focusing on the bucket issue since its the biggest nuisance, but ill mention all the issues since they might be related.
Bucket In/Out bogs engine excessively.
Boom up is not receiving dual pump flow.
Right track is much faster than left track with no load. (I have not checked with the pumps switched)
Neither track is very powerful even though together they easily bog down the motor up even a slight incline.
I have switched pump 1 and pump 2 outputs(and neg flow controls) with no effect.
Bucket in/out functions normally if "boom up" or "arm in" are called in conjunction.
I have switched the bucket 2/arm 2 pilot lines and the problem moves to "arm in" and "boom up" (the functions that pressurize the opposite side of the bucket 2 spool)
The pump control solenoid is working. (not sure if it reacts to load, but it does change pressures with modes)
Thanks in advance for any input.
