iforgotu812
I’ve got a PC 138US-10 that’s throwing the ca559 and ca2249 error codes. It starts fine and doesn’t blow any black smoke. It will run for about an hour when you first start it up the it will hiccup and bogg while digging and throw the codes. You can shut it off for a few mins and fire it back up and it will run for awhile and do the same thing. I changed both fuel filters and checked every line for leaks. The hand pump primes up and stays tight. Could it be the fuel pressure regulator causing this? I would think if it was the supply pump it would do it all the time and be hard to start up. What should the pressure range at the fuel rail be?
