Hello I have a motor grader gd655 cranks but doesn't start. no smoke when cranking, I installed new batteries due to low cranking amps, replaced fuel filters and injection pump still have the same issue. any advice is greatly appreciated
I'm not familiar with spill timing but if it's getting fuel at the injectors would you still see smoke with the timing off?Probably a new electronic engine of some kind. How was the injection pump timed. Was it on #1 Cylinder of compression and not by chance on #6 cylinder overlap. May or may not be able to help.
All I can say is that if timing is out just a little no start.
Simon C
