Kubota 080-3 Is there a away to tune the hydraulic system on an older Kubota 080-3. The motor bogs under small loads and seems taxed. Hydraulics are jerky. Whining all the time like its working too hard. Still produces maximum pressure and destrokes fine. Engine seems fine. Also the travel speed button is not able to shift between high and low. There is no signal coming from controler. But it shifts fine if you hot wire coil directly.
