Fordson dexta
Hi Bought this from a salvage guy a couple of years back. Got it running and most hydraulic functions working correctly. It has a pattern changer, but we think this is in order.
Go all functions properly, apart from bucket arm/dipper and the off set/knuckle boom.
The dipper does tend to lift a bit, when you lift the main boom, it basically comes in until the ram is fully extended on the dipper, then the boom lifts, other than that it won't move. The offset won't move at all with the pedal, unless I unplug one of the three solenoids below the cab, then it just goes all the way to the end of its travel, to move it back have to switch the pipes.
Looking at the spool block below the cab, starting from the left, first slice front blade, works normal, next the offset. Then the dipper spool, this is in a block with the slew, which works fine. Next block has the two track motor slices in, last block bucket and boom.
I'm confused by the amount of pipes I think are for the pilot circuit that go between slices on the spool block, would have expected one pilot pipe to each service? But we have say the boom pilot pipe to a T joint on the slice, and the T off go's to a track motor block? Dipper similar.
The fault is mainly connected to two adjacent spool slices, which both basically do nothing, not even change engine note or hiss of hydraulics. We think the pilot service works, as do the joysticks as if you swap things around things happen.
I suspect (hope) some of the pipework between the spool slices is wrong, I have attached a picture, sorry poor quality but can upload more.
Also unsure what the bank of three solenoids adjacent to the spool block do, maybe connected to the depth monitor?
