mam19582
Hello everyone.This is my first post. I have a mid or later 70's Kamatsu D31. I don't know the exact year so I'm guessing. I replaced a hydraulic junction block on the blade arm (left side). I bled the air out of the lines and through a past experience, I know there is a sequence with the bleeding plugs but I don't remember it. My problem is to steep of a tilt to the right and a bearly level blade to the left. About 15 years ago, I repaired one of the cylinders and had the same problem except an old timer at a dealer told me the order to bleed everything and who knows what I did with those directions. A tech came out to work on one of our end dumps and couldn't figure it out either, even after being told to leave the plugs alone and just crack the hoses to bleed the left and right angle cylinders. I know that's not the only thing I bled years ago. Well, I thought this might be the place to ask while in the meantime and sparetime, I'll be waisting alot of hydaulic fluid and probably my time. (the machine is antiquated) Thanks a whole lot
Mike M
Mike M
