John Deere 650K exhaust temp not getting high enough. Doc fault 5018 derating machine
GMcCannic
Ruston, La. 71270
It’s been a long expensive road with this machine. Most recently I Replaced a partial solidified dpf which i assume occured during many hrs of use and abuse as a rental machine while suffering along with a contaminated fuel system and I just replaced exhaust piping with hole in flex-tubing.Im getting a Doc system failure code 5018.0 and an egr valve short to ground 2791.6 which comes and goes also a 3251.7 dpf presssure error that will come and go.
The on board exhaust temperature readings seems to be correct when compared to my thermal imaging gun reading 977°F which is as high as ive been able to get the exhaust to go. I believe I’m looking for 1650°F. I was pretty confident I’d solve my problem codes when I replaced the dpf and the leaking tubing but they remain. Vin number in attachment
mg2361
Pennsylvania
Equipment Mechanic
5018.00 is actually Calculated Unintended Combustibles in the DOC very High. It gets that from seeing a temperature difference across the DOC it does not command. The first step is to have diagnostic software to check the temperature sensor readings after unit sat overnight. If the readings are the same, then you most likely have an engine issue.
GMcCannic
Ruston, La. 71270
Thank you for your prompt response and my apologies for my delayed reply. The first step is a tough one for me because of the cost involved doesn’t justify the the action suggested. For me to quire the diagnostic software my research shows it would cost me upwards of $3,600.00 or if I have JD come out I’m out $1,200.00. My other possible option would be to play parts replacer and purchase the dpf differential temp sensor from JD for just under $500.00. If code persist would that tell me I need to look for an engine issue rather than the dpf?
I don’t mean to come off as a cheapskate but the reality is that the investment I made in restoring the fuel system to recover the tractors performance has cost me more than I was prepared for. I can easily recover my money if I can work the tractor but I do not have the resources to dump another grand in to test a sensor. I can spare $500.00.
As I was contemplating my options and writing this reply I was idling the tractor to build my batteries up. The engine idled up and the dashboard screen reported dpf filter soot level high requires cleaning. So I with great excitement and hope set out to initiate a parked cleaning. Everything looked good and it idled up and the screen read preparing for parked cleaning and the countdown progress block appeared on screen with a 0 next to it. But it never increased from zero.
I manually stopped the process and it read soot level low. Let idle for a bit it returned to soot level high I tried again same result. Checking my active code list I find the attached new code and prior intermittent egr code.
The filter I used to replace my solitified dpf was used. I can’t say that it was necessarily cleaned but it sure looked good! lol. Perhaps need to take it to be cleaned.
I don’t know if any of this changes your suggestion or not but I’d appreciate your feedback on this new information if at all possible.
mg2361
Pennsylvania
Equipment Mechanic
Unfortunately, when you have 3719 codes, that requires dealer intervention. The root cause still will need to be figured out, but the dealer will be needed to get the 3719 code out of the system.
