I have a john deere 490E the machine runs and functions good except for the stick in and out. if you bounce or surge it she'll take off and move. or a load of dirt already extended out a little. it'll go when activated. also digging if there pressure against boom she'll drag the machine. but if you let it hang limp no load she'll barely move unless you curl same time then she'll move half ass. I,ve cleaned all hydraulic filters including in the tank new oil. I,ve tested pilot pressure by adding tee at the caps. this (stic)k spool has about 500-550psi while activating the fucntion. all the other spools have 850-900 while activating.
so I swapped some control lines. the problem stayed in that (stick) spool. Now i'm wondering if there are orings under that cap. or if I should be looking at the porportional control valve. or maybe somewhere else. i'm sure some one has had this same issue with this machine.
