You returning the pump to the supplier ?Yes it was rebuilt from a shop bench tested prior to shipping
I’m sure if you asked the supplier to flow test the pumps individually they would have no issues doing that.This is the original pump test I did finally receive it. I do question how they did the test compared to flow test instructions in the manual bc it seems them tested at the same time and not independently.
Basically, all reading were the same as before when I sent the pump back and they found the issues in post #228Ok pump was installed today and no improvement once again. Pump 2 delivery pressure was at 841psi when boom up function was activated and Pump 1 was at 5600psi when boom up function was activated….any thoughts? To me pump 2 still isn’t right in the machine.
Gauge in port 19 reads 650psi on pilot pressure only when operating right track in reverse. When operating forward no reading is displace display controller shows pump 1 is putting around 5400psi outTee a gauge into port 19 right propel pump 1 and see how much pilot pressure you have to actuate propel spool just to verify there is sufficient pressure coming from pilot signal manifold.
