Hi all I am working on a John deer 325 skid steer with the 5030tt001 engine the problem is I have no low pressure fuel. I have done all the checks of pick up tube lines and filters etc basically I need to know if the fuel transfer pump runs directly off the cam or is there some sort of follower? I replaced the pump already but after it won’t run with the new pump I dug in further to realize that whatever creates impulse for the pump is not doing its thing I can pump the plunger off the machine and both the old pump and new are fine. I should mention unit will fire so cam is turning
