Steve Austin
Sorry I missed your post 17 about your son using the clutch.
At this point you need to locate the plug in top cover remove it there will be an 1/8 inch pipe plug you will need to remove.
The plug takes a 3/16 Allen socket make sure your socket has no rounded edges if someone has over tightened the plug it can easily be stripped tap the socket into the plug to make sure it is seated good. You will need a good 300 psi gauge and a hose or fittings to connect to test port. Look for around 180 psi of pressure.
