RockyHillRanch
2012 Kubota SVL90 Standard Flow,
When I am attaching the hydraulics for the grapple to the machine, an excessive amount of oil flows out of the case drain port while i am connecting. Once the hose is fully seated, it doesn't leak anymore.
Is this a pressure relief mechanism? I tried manually reliving the pressure, but no change. Or is this pointing towards worn out o-rings? I lean towards a bad seal, as it is not a little amount of oil that comes out.
Ideas? Thanks
Ideas? Thanks
