1693TA
How do you identify these? I cannot locate a tag anyplace and the adjustment nut is all the way in so needing at least a minor rebuild.
Thanks,
Thanks,
It's been screwed out to end of yoke rod correct? How old is it? IIRC RK351 series. Normallythe adjustment nut is all the way in
Fantastic, and thank you.Yeah it's a old 3500- the revised later version # I'm thinking is rk351. The real difference is
in the jaw pins and pivot pins. The late series is easy to remove the pivots where the old is
torch the pins off in sections and drive through. But not a problem to get a kit for a old style
3500, just get a new set of pivot pins and stand bushings. 48" is the standard height for a
13'6" configuration.
