Hitachi EX75UR-3 fault code
Tadhg
Ireland
Emailed to you .
Hi, Would it be possible to send this to me too please? Also where are you getting the error code from? I have the same screen as in Barteks post above but it doesn't seem to be working. It's a machine I purchased recently to use on a self build.
Artem
РФ
Have a good time.
Please help, I'm restoring Hitachi EX75UR-3, there are error codes
E11
E50
E51
I can't find the decryption
If there are electric schemes, it would be great at all. Thank you very much
Diesel Dave
Ontario Canada
E11
E50
E51
Your serial # prefix is 10V ?
The electrical schematic is in the Operators manual # EM10VEN13 available at the Deere bookstore as a free download.
https://www.johndeeretechinfo.com .
I will try and find any fault code info.
Artem
РФ
Oh, thanks for the support. I've already solved the problem with this forum member. The thing was to cut the wire on a sensor that's attached to an arrow finger at its base. The key error was e50. In fact, there's still a lot of work to do, the excavator has been used for a long time without proper maintenance and even local fire survived, so far replaced all high pressure sleeves, absolutely everything. And now I'm restoring electricity, also repaired hydraulic pump, main
