blakeusa52
Engine starts and idles and will shut down. No increase in engine when throttling up. Removed the linkage from the fuel pump and can rev the machine by moving the lever on the fuel pump. Put it back together and adjusted the linkage a bit and it ran fine for 5 min then stopped again.
I have a service manual that shows a long cable like 120 inches which is what appears to be on the machine. Seems to run from the intrrior control panel back by the batteries then to the engine...connects to a swivel rod that's about 12 inches which i belive connects to lever on the fuel pump.
I plan on removing the cable tomorrow... but is there an electronic or hydro control or just a direct old school cable on this machine?
Service manual shows just long cable but my parts manual shows something completely different. I must have the wrong parts manual. Not sure if I have an electronic throttle control. Just a lever on the dash that runs back to the engine..
If anybody has an ex150 V parts manual please let me know.
Thank you in advance.
