Chantrelle
Hello, I’ve got a Hitachi 75ZXUR excavator it has oil leaking from what I believe is between the two pumps. I’ve taken one of the pumps off multiple times now to try to address the issue this most recent attempt to fix the leak. I took the pump off, cleaned everything with fine grit. Sandpaper tried to find any warpage on the two faces. Nothing was obvious tried to find any high spots again nothing very obvious I replaced the two O-rings between the pumps, which I believe are supposed to keep the oil from leaking out.
This is the third time I’ve replaced these O-rings now I believe that the oil passing between the pumps is at a low pressure and the oil is leaking out just from the pressure of gravity and the oil in the reservoir.
After putting the pumps all back together and refilling the oil last week. I’ve already lost a few litres of oil over a week from this leak and one other leak that I’m having a hard time fixing that appears to be coming from a 2 inch rubber hose I believe is called the suction hose that goes from the bottom of the oil reservoir to
the pumps, with this leak at the suction hose I’ve replaced the rubber hose and hose clamps done my best to line them up with the nipples on the pipes they connect to.
I will provide pictures as well as the tag that’s on the pump. Is there any other details I can provide that would be of help please let me know. Thank you.
