Also its a single rear axle which is odd to me for that weight.
Probably a miss quote of weight … or there are more than 2 axles for the whole rig right/wrong ??? to get that kind of a weight figure ……
Anyways, I built a parking turnaround area c/w a 200 meter long entrance driveway at my/our local Fire hall …. the new additional hall we had built was for 3 apparatuses, 2-Engines/pumpers and our Tank tender ……
The contract involved removing and building a supportable "Year-Round" accessible base …. where we are, we have to deal with winters (like starting now) and ending when "Break-Up" is completed (that's when the Frost is coming out of the ground in the traveled drive area, as much as 3-6' deep, things get really really soft) usually in April/May ….. the area had to support our trucks no matter what !!! ….
I started by digging out 3' deep, slopping the base 2% away from the foundation ….. (oh, btw, our building codes here call for footing depth to be at min 42") ….. I laid down a total of 1000 yds, first was 2' compacted progressively and adding water to achieve ~ 95-98% proctor (using my Bcat with the Allied Skid-Pac, we had a thread here on HEF discussing that) …. using a 3"minus screened pit-run material maintaining the top to the original start of 2% grade …… we then laid out a woven heavy gauge geotextile 12' wide rolls, the geotextile prevents the soft muddy stuff from hydraulicing up to the surface as well it allows all moisture to go down and stay down, once it's down there it'll follow the grade away, then again added another 12" of the 3" minus compacted (also to the 95-98%) ……. I topped it off with ~6" of a crushed 1" minus Road-Mulch material, also compacted.
That was ~4 yrs ago, that's 3 winters ago and when we roll out the heavy s/a engine, with 800gal of water and equipment on board, during "Break-Up" it does NOT even leave a 1/2" foot print, basically just the tire print, there is more damage done by the rookies dry steering the trucks when turning to back into the hall ….. Proven Success !!!
Now IF ONLY I can get the picture re-sizer to work i'd post the pics !
