rod miller
I have a 1973 galion t 500 grader with a leaking wheel cylinder ,it has keyed axels what is the best way to remove drum ,made a puller but still no luck
No heat needed with the knocker I described above!!There is a video online removing a Champion hub. They used a rosebud to heat the hub and a big hyd. puller. I think it was on the Vanatter site. I have 1 brake line disconnected and plugged on my Champion but don't think it's a big enough deal to pull the hub. The brakes seem to work pretty good for my needs. The cap on the master cylinder could fit a little tighter though.
As long as the solid piece is firmly against the end of the spindle the exposed threads will not be harmed. We haven't used those puller holes on any of the graders with this sort of hub (tapered. keyed) since the 80's. This works, trust me!!!!So with the knocker welded to an axle nut there's a few threads on the spindle not used and it leaves a space between the nut and the hub? Champion hubs have 2 1" threaded holes for a puller. I can see the knocker working if there is tension on the hubs from some kind of puller set up but just by itself pounding on the axle there's no contact with hub.
Correct, it is the shock that loosens it. It "can" be done with the grader sitting on the ground, but it's easier with the weight off the wheel. The poster above who welded the plate across the nut uses the same idea, but driving in figure 8's and taking the inner bearing retainer off were never part of our process. We are shocked at how well it works, ands it is amazingly fast. Issues can arise if silver anti seize was used. But we don't see much of that. I could sure post a video of one being knocked off!I'm not worried about the threads. I'm wondering how the hub comes loose if there's no tension on it? Your knocker is basically just pounding on the spindle. Is the shock what causes the hub to come loose? It would seem if you had a heavy bar across the knocker with bolts to the hub, the knocker would work the best. Tighten the bolts, hit the knocker, tighten the bolts again and hit the knocker.
Yes, the opposite side wheels can be on the ground. I know nothing about the back story on that tool, but I do know it works like a charm in 90%+ of cases. Like to give an award to whoever came up with the idea!!I wonder how Galion came up with the knocker? Does it still work if the wheels on the opposite side are on the ground?
