Hi all, we have a 314dLCR. Was running good. Took it to a job, put fuel in it only to have problems dying. Figured out when they refilled our big fuel tank at home the guy left the cap off so we drained the tank on the excavator and sucked water out of our big tank at home. New filters and new fuel (from local truck stop, not our big barrel). Much better but limited power and will die under hydraulic function at idle. Thinking maybe some water left in the system or junk. Trying to locate the little screen in the banjo bolt. No fitting on the bottom of the hand primer. Any help would be appreciated. Thank you
Sn#CAT03114DHSSZ00505
