Esco bucket 42 inch 65mm pins tag is gone what bucket teeth do they use?
earthscratcher
iowa
excavating contractor
never had a Esco wondering what kind of teeth they use thanks
bam1968
IA
Excavating Contractor
I might be wrong but it looks like they would take ultralock teeth
earthscratcher
iowa
yes bucket is shot,just going over options to bring back from the dead.ultra lock teeth and holders are not cheap +cutting out and welding time.bottom is worn really bad to,i just don't have a 42 in the arsenal,
maybe I should just grab a 1/2 piece of hardox and weld on, for basement and septic stuff I don't have any smooth cutting edge stuff. anybody try that, would be a good Frankenstein bucket, torch couple holes in the hardox and bolt different shapes to bottom, for different size pipe/culvert bedding. any body try that ?
KSSS
Idaho
excavation
Ultralocs are expensive, but really nice teeth. I use the 30F flang teeth. Really nice for cutting flat grade, and easy to switch to aggressive teeth when you need to. I have been able to find the teeth on Ebay for about half what a dealer charges, not sure on the holders.
