Blueacre
I purchased new piston cups for the hoist on my farm truck. It is an Edbro LNC - the ones with the tank and valve on the bottom of the hoist cylinder. It is a 3 stage cylinder.
I got the hoist apart with no problem and ready to install the new cup seals - they flare out quite a bit to the seal lip and are a very hard fabric reinforced rubber. I am not 100% sure how to install them and get them past the internal threaded end of the cylinder without damaging the seal lip. I am thinking I could wrap a piece of 3 inch wide brass shim stock I have around the seal area and start that into the cylinder till it is past the threaded area and then push the piston through the shim stock and into the cylinder.
Appreciate if anyone with experience rebuilding one of these hoists has any suggestions - Would it help to heat up the seal with a heat gun before pushing into the cylinder ?
Typical pictures of this style hoist and the cup seals attached.
![hoist.jpg hoist.jpg](https://www.heavyequipmentforums.com/data/attachments/276/276226-651592d35e8104d742cd9fab851eac4c.jpg)
![seal.jpg seal.jpg](https://www.heavyequipmentforums.com/data/attachments/276/276228-c63f1f962658a81e6d43d9c4bceda74a.jpg)
