DozerTech78
Working on a John Deere 862, Went down on a job and wouldnt move. Checked basic things, parking brake is released, trans is full of oil. Engine runs fine. I didnt have many tools with me at the time so I did what I could to try to isolate the issue. Im familliar with the electronic shift controller which was my main suspect at first but after starting and trying to get the machine to move, i realized I can put it in gear and hear/feel a thump in the trans like clutches are engaging. The trans output shaft will move slightly but no matter how much throttle i give it, it wont move. Id like to tap into the clutch ports to see what pressures its getting just to see what direction to go from there, I can grab the output shaft and wiggle it and watch the input shaft turn with it. The trans input shaft spins the entire time the engine is running and when i try to put it in gear so I would assume the TC is not slipping. I know its no a lot to go off of until I check pressures but just didnt know if anyone here has experienced similar issues?
