Having trouble with my 160 CLC excavator . Would not started and found out it was the 24V Fuel Shutoff solenoid not pulling in. So I replaced it with the wiring that came with it as well. Turn the key the valve plunger does not pull in still like it should go back to dealer exchange it and get a new part. Same issue occurs checked the fuses like I organically did and all are good and right. I see the auto throttle control adjust once the key is turned but nothing happens with the fuel shut off. I pull in the plunger and have the key turn and it starts like it should.
Figuring something maybe with a diode or something with a relay not activating it. Looking for some assistance here before I burn myself out chasing the wrong stuff.
