Damn you, Milwaukee
colson04
Delton, Michigan
No once the lock and lube is stuck on it. To get the coupler off with out damage to the coupler.
Eh, that can be tough. I usually lean the lock n lube at and angle and eventually it'll break the seal enough to let the pressure squirt off to the side. Yes, that risks ruining the seal inside the lock n lube. Other options are buy the lock n lube pressure release system for your grease gun, or use a wrench to crack the line open to release pressure.
Deere500a
Castro Valley ca
The zerk doesn't take Grease adjust the angle or tap pin with a hammer but times remove zerk some PB blaster in the hole dry ol grease need to be moisted & reinstall no go replace zerk & get a Milwaukee
Shimmy1
North Dakota
I cannot get behind a Milwaukee grease gun. I have one, but it only gets used when it's cold because the batteries last longer than my Lincoln 20V. I think it's rather clumsy, and takes steady pressure on the plunger when it's cold to pump.
As far as the lockNleak, no thanks. I don't know how some guys love them, and some hate, but they are definitely not for me. Tried 2 about 8 years ago. One lasted about 3 tubes, and not once had been stuck on a zerk. The second leaked after the second zerk. I use the standard Lubrimatic couplers. Buy them a dozen at a time, usually get through the season with that. I am considering buying about 1000 new fittings and swapping every single zerk in the fleet, and see if that stops the coupler issues.
hvy 1ton
Lawrence, KS
JLarson
AZ
I picked up a green 3 line M12 laser a little while back, good laser, it's nice to just grab another M12 battery and not get new AA's or whatever if you're doing a lot of work.
