Damn you, Milwaukee
colson04
Delton, Michigan
You're not supposed to put a snipe on them. LoL What is that wheel on? Odd bolt pattern.
John deere ag tractor. One set of bolt holes is for the adjustable wheel hubs. They have a wedge fit to the axle shaft allowing the farmer to change wheel spacing for different applications. The second set is for the wheel to hub mounting.
Edit: that is just the outer hub for the duals seen in the picture. The wheel with the duals is off.
Here is what the hub looks like
Why would a farmer want to change wheel spacing? One tractor for multiple tasks.
Years ago, we had a John Deere 7810 that we used to pull a 12 row planter, then a side dress applicator, and then pull the round baler in the summer. Also used for light tillage work, or backup on manure spreader. For the planter, we moved the inner tires closer to the frame to allow for duals to be mounted to the axle, and all tires were spaced to fall between planted rows. After planting, the duals were removed and we knifed in our side dress fertilizer with this tractor. Right after side dress, we slid the tires out to their widest setting, and reversed the front wheels side to side (offset wheels) to widen the tractor to straddle the wind row for making round bales of dry hay or straw. When the baling season was over, we would narrow the wheel spacing back to row crop settings for next spring and put the removable hubs for the duals back on the axles. With the dual hubs already mounted, the dual wheels go on pretty quick, so we left them off unless we really needed them during the winter. During a mild winter, they never went on until spring planting.
Today, we just have more tractors. One is set wide for the baler, two are set narrow for feed wagon, rest are set at row crop width, and they don't ever change.
JLarson
AZ
The holidays are always an expensive time if you're into the red tools, especially when one of your suppliers is running a buy two batteries get a free grinder along with other deals, gets outta had real quick.
Anyone tried a Milwaukee cordless heat gun? Sounds like they don't put out the same heat as a corded gun. I'm usually just needing it for heat shrink, occasionally thawing a lock or hydraulic fitting.
https://www.milwaukeetool.com/Products/Power-Tools/Specialty-Tools/Heating-Tools/2688-20
It's ok for shrink, a bit slow but so is everything else compared to the gold standard in cordless heat guns, the MAPP torch lol
Old Doug
Mo
I have some battery stuff and i like it but its hard to use it were its really wet,dirty and oily. I would rather use air stuff then.
Tyler d4c
Salix Pa
I hope the flexzilla is good I had the worst luck with lock and lubes the one on my milwaukee gun pushed the threads out of the piece that seals on the grease zert. The look and lube tire filler is the bees knees tho best ture filler I've found so far
IceHole
AK
Still waiting for my 12 year old Milwaukee stuff to kick the bucket before I upgrade. Even my 12 year old batteries are still holding charge just fine.
Got a pretty smoking deal on some 20 volt Dewalt stuff and I'm quite impressed with it so far.
I've released the smoke from a drill and saw recently that I bought in 2013. And a grinder from maybe 2016 or so.
IceHole
AK
Been running mine for 5-6 years without trouble. Don't use a ton of grease though, maybe a 4-5 boxes a year.
Old Doug
Mo
Just got a Milwaukee grease gun . My f600 needs to be serviced so that will be a good place to try it out.
Old Doug
Mo
We probably use 3 maybe I'm just abusive
I try to take care of stuff and not buy stuff that looks like it could need special treatment . Milwaukee stuff is good and tuff but not like the air tools they are replacing or the old grease guns that could be left out in the rain or dropped in a bucket of oil.
Tyler d4c
Salix Pa
No I mean abusive to the lock and lube the gun it's self is quite loved
colson04
Delton, Michigan
I've been converted. I've had a 20v Dewalt grease gun with lock n lube tip for a few years now. We had the same at the farm. Over the winter, we picked up a milwaukee because it was a better deal. That milwaukee grease gun is way nicer than the dewalt. Pumps faster, primes quicker. I never thought I would use the pre-set grease dial, but I use it weekly for lubing certain pieces of equipment. I also found myself using the 2 speed setting when greasing our grain drill. Been a very versatile tool for us and gets used daily.
