just bought 6r xl series 2 with the c9. everything in the past has had the old pc 3306 or di 3306. what is every ones take on this machine vs the older 6r's as far as power, fuel economy, reliability. any advice on do's and don'ts on this machine vs the older ones? what is the best engine oil to run in these engines, I am hearing to keep it clean and change often? this one has about 10k hrs on it and only had injectors and pump replaced in last 1k hrs. are these trans any better or worse than the older d 6r's ? what is the recommended oil for them, I am used to running 30w engine oil in my old 7g trans.
