D6N pivot shaft
QuickTrax
Houston
This came into the shop today. Has anyone ran into this issue? If so, what was the fix?
Thanks, QuickTrax
grandpa
northern minnesota
Yup... ran into it before.... pull the roller frame off,, clean it up and weld it all back together,,, then cut a ring out of at least 1/2 inch thick material slide it from the inside over the broken area and weld in place. Its held for 4 years for me on a D4H.
QuickTrax
Houston
I appreciate the advice grampa. The problem we have is it cracked through the press fit of the inner bearing. we are thinking of cutting the pivot shaft housing off of the rollerframe and machining a new one and welding it back on.
2stickbill
Romayor Texas
Sniffin diesel fumes.
Thanks, QuickTrax
Dang I wonder if I know who owns that dozer.Tell Tommy that must be one of my ex employees machines.That's how good his top hands are at maintaining the equipment.
grandpa
northern minnesota
Yes , I see, I caught mine well before that degree of failure.
Ajkc
manitoba
Hi Every one i am new to this forum been reading here for awhile lots of great people for some im not trying to hijack your post but for some reason it wont let me post a new one???? I have a question about our 93 D6H that we just bought it has the Diff steering and im finding the twist grip from fwd. to rev. is very tough to turn is there any fix for this ???? thanks in advance
Ajkc
manitoba
Thanks for the quick reply i guess i havent made 5 posts yet sorry its a 3ZF prefix
Info on it's way to you. One thing I forgot to mention is maybe all it might need is to disassemble and throughly clean the linkage, both at the transmission end and the cab end. You might well find it's just full of crap that prevents the cable moving freely.
Davvinciman
So. California
Operating engineer and business owner
Wow! That is, no doubt, the right way to do it if you have the bucks but I think Grandpa's version of the fix mixed with a re-weld and boring of the press bearing mount would be a lot less expensive. You would probably need that part shipped in from Indonesia or other location (rare that a dealer has that on hand) and if that happened because of a an over zealous operator or just negligence, you going to have a few more bills down the road with other parts. BUT, your fix IS the right way to do it. (I'm just cheap)
