Cummins CM870 ecm
Tyler d4c
Salix Pa
I've been asked to fix a no start situation.
Both key on and constant power to ecm is blowing the respective fuses. The these pins are showing a oms reading to ground.
Appears to be shorted to ground internally. Should I investigate and farther or is it safe to say the ecm is junk.
