Cartoondude135
Remember this? https://xbroom.com/products/cold-in-place-recycle-train/
Although there weren't many pics of this trailer on auction sites, that page does list the name of all the smaller parts and pieces it utilizes to create this mobile asphalt recycling machine/contraption/factory on wheels.
Here's all the parts and smaller machines it uses:
I managed to find blueprints of the train's/trailer's "heart": the Caterpillar C9 – 300 KW rated generator.
From a .pdf specs, dimensions sheet, or a brochure; the blueprints that show the object's exact dimensions will make it much eaier for me to transform this thing into a 3D model. But the blueprints for the other things - so far are proving to be tedious because they yield no search results in Google.
So if you can help link to the missing parts' blueprints, please do. Thanks to this new discovery, I feel much more relaxed and this close to transforming this thing into a 3D model much easier.
Thanks to the control panel of that Cat C9 – 300 KW rated generator, I'm starting to better understand how this thing is created from scratch.
- Cedarapids / JCI 5′ X 14′ Horizontal 2-deck screen.
- Eagle iron works 36″ X 8′-6″ twin shaft pugmill.
- 48″ Wide horizontal impact crusher w/125 horsepower electric motor.
- 48″ Belt Scale conveyor, underscreen feed to pugmill.
- 24″ Return circuit conveyers. All material 100% sized.
- Auxiliary hydraulic pump that actuates the following:
- Front landing legs. Conveyor Tip-up picture
- Rear steerable tandem axle.
- Train cross slope up to 6% left or right.
- Belt scale conveyor tip up for easy access to pugmill.
- Crusher access door.
- Caterpillar C9 – 300 KW rated generator.
- All electrical switch gear.
- Emulsion and/or Foamed Asphalt Additive system consisting of:
- Positive displacement asphalt pump.
- Variable speed Electric drive.
- AC Varidrive controlled for quick response and high reliability.
- Positive displacement meter for accuracy at low and high flow rates.
- Full circulation of asphalt through system and back to tank.
- Automatic Spray/Return valve actuation when material enters pugmill.
- Uses standard milling machine load conveyor.
- Nescon computer control system. With large LCD character display
- Travel weights: 38,000# rear tandem, 27,000# on kingpin. Total: 65,000#
- Shipping width: 10′, Length: 46′. Kingpin to tandem: 34′ . Height: 14′
- Option: CAT -350 KW Generator and 30″ conveyor belts. Shipping width changes to 11′-6″ and weight increases to 68,000#
