cherokee101
I am not getting younger. Though I don't have money to blow I have been thinking of upgrading some of my old equipment. Specifically my Schaeff SKL 831 loader with the mighty Perkins Parma engine and my uber reliable Komatsu PC-40 that has done things no small excavator should do. I am leery though because of all the electronics on the newer machines. Electronic and electrical troubles that can render a solid machine into a boat anchor. I doubt seriously they would last even as long as I do without serious problems. My machines stay in the barn when not in use and the cats protect them from vermin and still I chase gremlins on things like the JCB 7 contact points safety interlock for starting the 210S. Is trading old and worn for new fangled with lots of bells and whistles I don't think I need or will ever use really a step up or down?
The 210S gets new hoses, a bushing or two and a cylinder pack here and there. The old deep throw Perkins continues to reach down to the bottom of the barrel and lug away so long as I don't lock the emergency brake and the torque converter gets the right old Ford blue ATF. Nothing I have beats it for mobility, burying dead cows, cleaning out water crossings on the creeks, cleaning ditches and general heaving things around.
I am looking at Case 331F and a 57 or 80 size hoe. Also considering the equivalent in Bobcat, JCB, Volvo, New Holland and Wacker offerings.
Experiences of others I read are as I expect, chasing lots of gremlins in the electrical / electronics system. I have a friend that buys new equipment regularly to prevent repairs and downtime. His tactic seems to be working less and costing more since he can't fix a thing himself. He has been searching in vain for older equipment in good shape instead of new. Two events have driven him this way. One was a $30,000 wiring harness for the "space age" experience Cat grader and the other was $35,000 in repairs and a tech to come from somewhere for JD to reburn his computer with an after market fix to a screw up JD won't own up to. Tractor runs perfectly now. That computer fix was $5K after JD hit him for $30K for no solution.
What happens to this new fangled equipment with lots of junk on it you mostly don't ever use or the engines that now more closely resemble a Formula I or Prat and Whitney F100 engine in complexity when it is not fixable way before the time the iron wears out?
The only reason I can think of for computer based load management is the too small engines in some stuff and bad operators. Ditto for a computer that has load settings for different attachments. What is there to run that requires so many load management changes? Most used equipment I see has never had anything hooked up to the auxiliary hydraulics or the multi-pin connector anyway. The Wacker-Neuson whell loaders are loaded with hydraulics that never get used as they are eaten up loading fertilizer. Yeah, you really need all the bells and whistles to shovel salt don't you? How about compost and cow **** in a dirt yard?
I may just keep my old stuff and argue with it until one of us dies.
Your thoughts?
Your thoughts?
