Supercomp517
I've found a couple of dozers that I like for medium farm work, building ponds in clay and clearing 50-60 acres of medium sized trees, brush etc. I'll probably keep it 4-5 yrs and sell it.
If you have run both of these, is there a significant size or power difference in the 42HP and 9K lbs between the 2?
2002 750c 148 Hp 33K Lbs cab, sweeps, SU blade, single shank ripper
2002 850c II 192 hp 42K lbs cab, sweeps, SU blade, single shank ripper ( new pumps and drive motors, both sides zero hrs, 1 owner )
The 850 is $21,000 more
I don't mind spending the extra $ on the bigger one but only if there is a noticeable difference in power ( or other differences you can fill me in on).
Thanks for your thoughts
