CMI milling machine
Lewis12
Texas
This is one them older orange color type models with the big drum in the middle. Just wondering if anybody had issues with the wheels won't line up. Back wheels fine but my fronts won't line up.
Bls repair
S E Pa
Equipment operator,mechanic
Can this machine ,crab, duel axle, single ,axle steer.
muncherman
emerald queensland australia
Its a CMI rs-500 model 1994
CMI RS500 is a rubber tire soil stabilizer, not a tracked milling machine. It can't crabwalk.
The cmi rs500 has four steering modes front /rear /crab and articulate so yes it can crab walk
The steering can be easily calibrated and all eight sensors are identical for ease of spare parts [ one on three of the four legs for height as two r/h legs are tied as one /one on each leg for steering and one on the steering wheel under the dash} if nobody has been adjusting the calibration prior to the problem i would be checking the small flex drive coupling between the leg sensor and drive pin as it may have failed or loose on the shaft
