Cat D7G year model
keith-50
Elgin,TX
Can someone interpret a serial number for me. Just bought D7G serial number 92V 8493. Arrangement number 8P5458. What is build date? Just curious why this dozer has wire screen hood instead of solid metal hood. The engine sidecovers are also wire screen. Look to be factory covers but have screenwire.
.RC.
Central Qld, Australia
D7G Track-Type Tractor
Machine Serial Number - 92V08493
Machine Build Date - 1979/09/01​
Product - Entire Group (92V08493)
Part NumberSerial NumberPart Name
8P-5458Product AR
keith-50
Elgin,TX
Can some one please tell me what winch in on my 1979 cat d7g, no name stamped on outside of winch, did find small tag on right side , 6/8 p-3478, i need to purchase a repair / maintenance manual, thank you
The 8P1082 cast on to the Cage identifies it as a Cat #57 Winch.
There are 3 Serial Number prefixes for #57 winches; 29U, 30U, & 31U. Of those 29U is the most likely as it is the only one listed as having been fitted to 92V-prefix D7G tractors.
All three are covered by the same Parts Manual UEG0587S.
D6 Merv
Coromandel Peninsula. New Zealand
Self employed bulldozing contractor with a D6D D4E
yes Cat 57 winch. the 3 different serial numbers cover fitment to powershift or direct drive D7G and a low speed winch version. All 3 have different gear ratios. rest of internals are the same. Not as solidly built internally as a Hyster or Carco winch. Input clutch is usually first thing to give trouble in them.
