Cat D6 9U-need an engine D318
Junkyard
Claremore, OK
Field Mechanic
So I rescued this D6 Saturday before the scrap man got to it. Not in bad shape other than a hole in the block. Anybody got a lead on a D318? D6’s, 12 graders, DW10 and other power units used them. Heck I’d take a complete parts machine if it wasn’t too far away. Hour meter says 0405 for what that’s worth lol.
FWD
Barron County, Wi
There is someone on the grader forum looking for a D318 engine, seem as though they are hard to come by.
FWD
Junkyard
Claremore, OK
Field Mechanic
I’d be stepping over them if I didn’t need one lol. Worst case I’ll fix what I have. I’ve made use of worse!
chidog
kent, wa
That is an easy fix, just sheet metal. Maybe the rest is not bad as well? Look, and more pics of the inside.
It would make for great entertainment to have two fierce members duke it out over a decent running D318. Could be an epic thread in the making.
The dozer looks pretty good. Is that your truck and like new trailer?
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
I know where there is an old D6 setting in the weeds. I know nothing of the tractor but am familiar with the owner. Threw a track and still sets right there as of last fall. Farmer owned and I get the impression ran till it didn't. Be down to our property within the next month and will rattle that cage if needed then.
56wrench
alberta
If i had known that running D318’s were in short supply, I wouldn’t have sold my old #12 for $1500:(
Junkyard
Claremore, OK
Field Mechanic
I've recently watched several go cheap on purple wave. Funny how that works lol
TJMcK
Eastern NC
I've got a D-318 taken out of a crane, stored inside, runs good. I want $2500 for it. It's in eastern NC
TJMcK
Junkyard
Claremore, OK
Field Mechanic
I’ve yet to touch that dozer since I drug it home. Could be full of diamonds or Hoffa’s final resting place. Who knows haha
chidog
kent, wa
I don't know. I've never had a reason to remove it.
Really? So you have the dozer with the hole in the plate? Lets see there should be the cast iron block window that the plate covers and the internal crank chain or train components.
I was curious if the block was damaged from the broken what ever that poked the hole in the plate.
