Cat d4d 78a water pump 2s4697 belt driven repair kit question
CaptainB
Laredo, Texas
Hello again
So the hydraulic cylinder rod is fixed but now the water pump bearing failed, I removed the water pump it says 2s4697
I used the search function here and got the parts diagram and I now know the repair kit for this water pump is a 5s-3351
I would like to know if this repair kit includes the bearing which according to the parts diagram should be 1b4107 if I’m not mistaken
Should I buy both the bearing and the rebuild kit for the pump? It’s belt driven most rebuild pumps I can find online are gear driven here is a photo
Thanks for all the advice I got on my previous posts
