Cat 627B Scraper Transmission Issues
gary1975
MN
We have a Cat 627B scraper I have been working on. The tractor serial number is 15S983. The scraper serial number is wore off but we believe it is 38V00045. The issue is the tractor and scraper transmissions don't seem to be on the same page as far as shifting goes. The previous owner rewired the machine from the transmission neutral/run switch to the back transmission. The most extreme example of what we are dealing with is the tractor trans would be in reverse and the scraper would be in a forward gear. Lightly pressing each gas pedal verified this without causing any damage. I verified all the wiring was good from the tractor trans switch back to the scraper trans switch. I also changed the scraper trans switch but it didn't help. I'm going to verify that the trans neutral/run wiring that was ran is indeed good. Any help or troubleshooting guides would be greatly appreciated. Thanks
gary1975
MN
Not sure what I'm doing wrong but the email you just sent with the electrical schematics is telling me "Requested conversation could not be found".
gary1975
MN
I started tracing wires from the transmission neutral/run switch and found a faulty manual transmission switch on the tractor. I had the machine running and in neutral. Measured 24 volts at the neutral terminal but also 19 volts at the reverse terminal. Switched to "Run" and put it in 1st gear and had 24 volts at all the forward gear terminals. Should only have been power at the 1st gear terminal.
gary1975
MN
I am looking for a new transmission neutral/run switch with 3 pins on the back to match the current one. Need power in the center and then "Neutral" on one side and "Run" on the other. Tried through Cat and they got me a 2 pin switch and can't seem to find the correct one.
So that switch is on the front end.?
Post a photo or two of it.
