henery
Cat 320C- hydraulics stalls the engine loaded or unloaded and at an idol or wide open. Injector pump has been redone and all new injectors. PRV Valve has been changed. flywheel sensor also. CAT has been out four times, from different dealers. They say the pump is bad and needs replaced. I took the pump apart and it looks good. I really don't think it is the pump. Seems like the pump doesn't ever destroke and I get the full 80 gpm all the time. Because the machine functions all work quick. I think it could be a wiring problem around the bypass switch under the right armrest. The wires have definitely been repaired in that area. Also, I have unplugged the wires to the hydraulic pump, and it makes no difference whatsoever. If I work the machine very long the hydraulic oil gets very hot. Can anyone help with this situation?
Serial # CAT0320CJPAB05482
