CAT 320 neutral safety switch
Big Iron
Oregon
Project Manager
320B s/n BR008xx
i have replaced the micro-switch at the N/S lever and rebuilt the N/S valve under the cab.
the N/S works fine when cold, once the hyd oil warms up it will sometimes work immediately and some times it will take 2 to 30 seconds to activate the hyd system. it will always work its just a mater of time. once it took 4 or 5 minutes to activate.
any ideas????????????????:Banghead:Banghead
Big Iron
Oregon
Project Manager
sorry bout that i left the 5 off the s/n it is a 5br008xx.
Per Eriksson
Sweden
When you rebuilt the valve, did you check the spool so it moves freely in the body when warm as well as cold?
You can also interchange the solenoidvalve with another one, 121-1491 is also used for swing brake and travel speed.
Big Iron
Oregon
Project Manager
thanks i will check that
rafi
indonesia
hi all. Just ask, did display shown actual position lever lock or unlock, i mean no delay
