YankeeFarmer
Cat 303C CR Serial No BXT41x. Auto Idle used to work as intended; machine no longer idles down during inactivity. This machine has an on/off rocker switch for auto idle located on the right hand operator’s console near the throttle potentiometer.
The troubleshooting procedure describes how to check out the entire control system, concluding that, if everything checks out, replace the $600 controller module. My issue is that the auto idle on/off switch does not appear in the wiring diagram, and I cannot find a separate schematic that shows it, so it is not clear how it disables auto idle. Furthermore, the troubleshooting procedure includes checks of the throttle potentiometer circuit, which is obviously functioning properly because I have full manual control of engine speed via the speed knob.
My current plan, when I have an opportunity to spend more time with it, is to verify that the implement pressure switch and the travel pressure switch both appear open at the controller module pins, to rule out that neither of them is shorted closed either within the switch or in the wiring harness.
Anyone here been through this, or have guidance for me? TIA
