ColdBlackWind
My machine started throwing this code intermittently. I couldn’t pin it down. I finally decided to check the connector for the sensor switch on the boom. I found the link for the sensor missing and the switch arm was moving around randomly causing it to throw the codes. Just a heads up if you are having same issue. Arm was $49 and easy to replace.
