FLYWHEEL PRIME
- Joined
- Oct 30, 2022
- Messages
- 60
Do I have anything against the 242d3? No comprendo senor.
So with that I'm guessing you think I should look at a different brand all together?As those Kubota motors are hitting 3 plus K here comes the gift that keeps giving. I believe this is the reason the new CAT machines are not running Kubota. Hopefully Taki bails on them as well.
They all have there share of problems. In cat though and though. At the end of the day at leaset locally they have the best parts and support even if they do need some extra fixing.So with that I'm guessing you think I should look at a different brand all together?
As Tyler pointed out they all have their issues. Its just this issue having to pull the motor to clean the DPF as part of a planned maintenance decision, just really sucks for the end user. I guess if you get one, just plan for that, or get out of it before that time comes.So with that I'm guessing you think I should look at a different brand all together?
Buy who ever is the most reputable dealer you have. This is like getting married, you're going to be building a relationship with the service and parts departments. Don't pick a bad one.So with that I'm guessing you think I should look at a different brand all together?
That is exactly right. How you run them makes a huge difference on how long the DPF will last. I think SCR is the very same. Run them harder and there are far less problems. I had a straight 4i DPF machine in 2015 it was a CASE SV300. We ran it hard for 2000 hours and not one DPF issue. I can say the same for SCR. I have yet to lose time or have any repairs related to DEF problems and I have had 6 machines. If you baby them I think your more likely to have emission issues. What makes it difficult is SSL/CTLs are frequently used that way.I think a lot of people simply don't understand the functioning principles of the DPF and how much variation you will get based on operation styles. If you take 2 identical machines, same motor, same DPF, same everything, and put them in 2 different operating situations over a 3000 hour runtime, they will see drastically different results.
A machine that is run hard at high RPMs will most likely not have DPF issues, but mechanical linkages will be worn.
A machine that idles constantly or doesn't see consistent loading and heat cycles will have premature DPF clogging and EGR valve failures, but less mechanical wear.
All that to say, DPF service is an inevitability, you cannot escape it, quite literally the laws of physics won't allow it.
Where in VA you at? I am near the airport with a 2021 299D3 with 2600 hrs that is throwing the 523602-0 code.DPF cleaning is only $250 bucks around here in VA so as long as it's only dirty it can be cleaned. 95% of the time turbos failure causes oil entry and costs to catalyst and failure occurs.
Why I stress checking turbos and air filters!!
