NWILMORE
I have purchased a cat 247b. Previous owner warned me of a battery draw and he always just disconnected the battery cable after turning off the machine. I have been able to find a 4 amp draw with multimeter after turning off the key. I traced it to the d+ wire on the alternator. It is only there after you cycle the key switch. If I unhook battery cable for a few seconds then reinstall the draw isn't there until you cycle the key on-off again. I have pulled fuses and relays one by one but none of them killed the draw. I tested key switch and it's fine, also took alternator off and repair shop tested it as ok. Any advice on how to find what is causing the d+ wire to remain hot after key is switched off?
