Thank you. So please can you do the tests below and post the results.
1. With the key switch OFF locate the 12-pin electrical connector directly underneath the RH joystick and unplug it.
2. Turn the key ON. Test the voltage on the machine harness side of the connector, marked R-C5, between Pins 1 & 2 (wires 994 BU and 997 BR). It should be 8.0 +/- 0.5v. Tiurn the key OFF.
3. Re-connect the 12-pin connector.
4. Turn the key ON. By back probing measure the output voltage between Pins 2 & 3 (wires 997 BR and 998 GN) with the thumbwheel switch in the centre postion.
5. Roll the thumbwheel all the way in one direction and measure the output voltage.
6. Roll the thumbwheel all the way in the other direction and measure the output voltage.
Post the results from Steps 2, 4, 5, and 6.
