Steve the Case Guy
Hello all, great forum here. I have used what I can that’s available for info but can’t seem to find an answer to a problem I have. Just the other day on my 580SE out of nowhere I think a relief valve got stuck open in the loader control valve because the motor stays loaded and I can hear a relief valve bypassing(I am touching no controls). The front loader now curls and moves entirely on its own without me touching anything, it does this slowly though. Given this backhoe is from 84 and the valve body has never been touched, I am going to tear down and reseal the whole control valve. I guess my question is, I have the large manual, is there a whole seal kit you can buy or am i going to have to buy each one separately Seems online the case dealer has everything. hopefully none of the relief valves need replacing since they seem to be around $200 a pop. Also I see where a pressure gauge goes to test pressure, does anyone know what size that is? Also since that’s for main relief how do you test the pressure of the bucket curl and lift reliefs? Thanks to everyone that’s on here for the help in advance!
