Rebuilding the dipper cylinder on my 1975 Case 580B with split piston seal heads. Using Hercules seal kit through CEA Services, seal kit number G105517
What is the correct Gland Seal order?
When I pulled it apart (not that it was put together in the right order in the past), the gland seal was facing in towards the piston and there was an Oring on top of it towards the seal head.
The new kit has a flat on both sides plastic shim (it might be called a wear ring).
With the gland nut in the orientation in the picture, does this shim go under the gland seal next to the split fiber wiper in the center (towards outside of the gland nut).
Or does the shim on top of the Gland seal, with the shim on the inside closest to the seal head (the same orientation as the stack I pulled out)?
Thanks
Thanks
