I have a 1965 Case 530CK and the left wheel has been locking up intermittently. It first started in the winter and I thought maybe the gear oil was freezing up (there is a frame leak somewhere so water gets into it). After warming up it mostly seemed to go away. Now however it is doing it in warm weather.
I have seen other threads where it was a brake issue so I was ready to take the recently replaced brake apart, however it only does it in 2nd, 3rd or 4th gear going forwards and in 1st gear going backwards...but I cannot get it to lock at all in 1st gear going forwards. That makes me think it may not be a brake problem as surely it would do it in all gears?
It also has another symptom... if I keep the clutch slightly dipped in the higher gears I can mostly prevent it locking when going forwards. BUT if I dip the clutch when in 1st gear going backwards it immediately locks up hard.
Any insights please?
