Zx40U3 Hitachi.
Bought last fall, haven't used a ton but felt weak.
Was going up a bank and realized the boom is weak to the point it won't lift the machine without alot of fuss. Just hits pressure relief.
I turned the relief up about half a turn, seemed to be fine. Buttoned it up and still an issue.
BUT if I give it just a tad bit of dipper, not even enough to really move it, the boom lifts without trouble.
In the book it shows the main pressure relief is adjustable. But mine is different, has a small pilot line sized hydraulic going to it with a T. So something sends hydraulic pressure to the relief and adjusts it.
Wondering if that's causing it.
Also having related issues with the grapple. I thought it was weak bucket curl, but pretty sure it's the grapple not "backfeeding" when pushed by the bucket. It's a well installed kit that feeds off the boom swing circuit (uses electric diverter valve to switch between the 2).
They are using a DCRV110-12N valve on the boom, which I think is supposed to allow backfeed/crossfeed? I've adjusted all over and either it works as normal or makes it no longer function, or function Verrry slow.
Thought it was a speed control at first asit acts like that.
